My acer laptop screen flicker at startup, the screen flicker more in cold place and takes time to normalize. In warm place the screen flicker is minimum and it would stabilize very fast. Please help me to solve the problem. When I connect my laptop to external monitor it seems my laptop work very fine.
In most cases like that,where we have screen flickering,first look at the graphics card maybe the signal flex from the back of the screen is well fixed on the motherboard.then if it is well fixed on the board you will need to look at the signal board at the back of the screen maybe it is well fixed if it is not well fixed then fix it properly to solve ur problem then if the problem still persist then u will need to disable the VGA in device manager.to get to device manager u will need to open my computer and after that, u can right-click on it and then click on propertise then click on hardware and then click on device manager where u can disable the VGA.
SOURCE: Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
SOURCE: acer aspire is not connecting to external monitor after system rc
If the external monitor was displaying during the system recovery, there may be a conflict with your damaged lcd screen so I would remove the cover and disconnect the cord to the lcd. Restart the computer and hope it works. -James
SOURCE: ''acer aspire one external monitor output splits exter
XP - Simply on a blank part of the screen right click mouse and select properties, you should be in display properties, selections are there and you should get hte picture(s) you want
