Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Oct 16, 2007
Using drop-down form field in a word 2007 template
The drop down field doesn't work. I create the a template with the field save it. create a doc using template and only the first selection in the list shows with out an arrow to select others.  Please help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12370
Points
18
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 03, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
15196
Points
12
The document is probably PROTECTED. unprotect the template first. this should enable you to make changes and use the drop-down fields.
Anonymous
Level 1:
  • Posted on Jul 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12370
Points
How do you unprotect a template please?
1helpful
{1800/796/0471} How to Change Default Email Message in Quickbooks 2020?
1 helpful vote
Customize email templates in QuickBooks You can manually create email templates for your QuickBooks Desktop transactions. You can also customize your email templates using pre-built data fields.
Important: To customize your e-mail template, the company file needs to be in Single User mode. Also, you must log in as Admin or have the permission to modify company preferences.
To set up your template:
  1. From the Edit menu, select Preferences then Send Forms.
  2. Go to the Company Preferences tab.
  3. From the Delivery Method Default drop-down, choose E-mail.
  4. From the Email Templates drop-down, choose the specific transaction.
  5. Select Add Template.
  6. Modify the email template as necessary.
  7. To insert pre-built data, select Insert Field. Note: In QuickBooks 2020, you can also add the customer's purchase order to the subject line -Customer PO No: (Subject)
  8. To set the template as default, make sure to select Default, then Save.
  9. Select OK to close the Preferences window.
If you batch email and the transactions still use the old template: You may notice batch invoices (as well as other transactions like estimates and statements) sent using the default or old email template after the template was changed or edited. This may happen if you created batch invoices before editing the templates.
To resolve the issue, follow one of the following solutions:
reference:
Yesterday I was creating a database template using mysoftware's My Database V6.5 product that I found on the internet (30 days free trial), I went to save the template and a huge portion of the template...
probably because free trials are only there to allow you to move around the program to see if it is suitable to your expectations
it is not there to use and save data as that is not the purpose of free trial
2helpful
Date in Word Docs
It is one way or the other. Either, you hard code the date, and it never updates, or use the auto-update.
For your purposes, since the date needs to be hard coded, for compliance, it looks like you'll need to edit the date manually.
4helpful
Word 2007 XML Error
After long hours searching solutions for this, i have finely got back my work and just in time for submission.well my problem occur when using Word 2007 so this is what i have done. :
1. Go to http://converter.tds.lv
2. Upload the docx document of yours and submit the form.
3. The result then will give you the ability to download varius file format. click the .doc file and it will download the file.
4. Open the .doc in Word 2007.
5. In my case i have got all the format and text back (but i found few text format missing/gone. Just a few though.). So it is better than nothing right?
No available fields in form wizard
If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
I am not able to create frontpage in new microsoft word 2006-07
Follow instructions to create web page using new word 2007.
1. Open word 2007.
2. Click insert menu, select Cover Page to select ready template or Blank Page.
3. Once your web page is done click save as.
4. Click Save as type drop down arrow then select "Web Page"
5. Click Save to your work
Hope this will answer your query.
Cannot open word 2007 files with word 2003
When you goto save a file in Office 2007 you need to change it to save in Office 98-03 format which is .doc , Office 2007 use's .docx by default.
To save it in the .doc format , simply click "Save As" , type in the filename in the box as you normally would....then underneath it is a drop down box, click on that and change it to the .doc
That will get you working!
Relation
populate the field's controlsource with =forms.formname.field and then from the properties of the new field change the format to a required one, on saving it will use that format.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
