Question about Jenn-Air JED8430 Electric Cooktop
Replacing burner/element Whirlpool Gold Electric Stove
I have a Whirlpool Gold Electric Stove, it has a smaller burner and a larger burner in each of the two front burners and the smaller one no longer heats up. I ordered a new element and receieved it today now - how do I replace it? The part seems too large to solve my small burner problem at all but need to get the top open to figure it out, HELP!
    Top Expert:
  • Jenn-Air Master
  • 64,733 Answers
6ya staff
SOURCE:
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Elements don't work
If the unit has some age on it the best thing to do is to replace it. You could end up spending more on parts than a new one would cost.
Posted on Oct 07, 2007
Anonymous
  • 59 Answers
SOURCE: GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
Anonymous
  • 58 Answers
SOURCE: My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Posted on Jan 09, 2009
Anonymous
  • 135 Answers
SOURCE: Jenn-Air electric burner goes to full no matter what the setting
This would be a faulty switch. Hope this helps!
Posted on Feb 17, 2009
loozerhater
  • 13 Answers
SOURCE: constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Posted on Apr 29, 2010
One of the burners will not work
Heating element might be not working in your stove.
Jan 15, 2013 | Maytag MEC5430 Electric Cooktop
Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Apr 25, 2010 | Kenmore 30 in.44084 / 44089 Electric...
New stove top is smaller than old one.
Never seen one the hole is cut to size of the top so in most cases you go like for like .
Oct 08, 2017 | Cooktops
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Electric stove
if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Apr 09, 2008 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
888 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
