I just received my Electrolux EIFLW55HIW yesterday and installed it. Everything seemed to go smoothly until I ran the Install Cycle and ended up with a code E32 and a message to call service. Service said it was an issue with the "pressure sensor," but declined to give more details. What the heck is an E32?
Pull hose off of pressure sensor blow through it to clear blockage put back together. Run a clean cycle with bleach. Hose gets clogged from fabric softener and detergent and sensor cant read pressure.
E32 indicates a problem with the pressure sensor. The service manual says to check the wiring (replace if bad), replace the sensor, if problems persist, replace the main circuit board.
There's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
Hi friend, thank you for your inquiry!
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
ELECTROLUX Washing Machines EIFLW55HI
4 Months old and now receiving Error Code E32
