Question about Minolta Riva Zoom 70W Film Camera
How does the flash work with the minolta Riva Zoom 70W film camera
6ya staff
SOURCE:
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: Minolta X370 film loading problem.
 First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably  because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs  two 1.5v  batteries to work ! )
Posted on Oct 11, 2007
Anonymous
  • 667 Answers
SOURCE: lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Posted on Dec 30, 2007
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: no shutter/film advance
Check and see if the mirror is not moving.
The mirror not moving is not the reason your SRT is not working. Mirror flip-up and release is one step of the shutter release sequence that all single len reflex cameras do: the mirror not moving is a symptom that the shutter release sequence was not fully engaged, or is "out-of-sequence".
This problem does happen to older SRT's and is, best case, easy to fix. Two ways this happens: best case, either the advance lever was not fully wound (at the "second to last shot") and by depressing the shutter release button at the shots afterwards you're allowing the camera to bypass starting this sequence: a shop can "trip" your camera to its proper sequencing, but it may happen again because of the second problem described next.
As second-best case, on SRT's the pull-rod in the bottom of the camera (inside the bottom plate) that connects the advance drum Y-lever to its cocking lever becomes "stretched" at the end curl: this is a common weak-link in SRT's. Again, this is a 10 minute fix for a shop (don't do this yourself) to retension this rod and resequence your camera to working order.
Alternatively as a worst case, the mirror lock & release levers or more bottom shutter release mechanisms have become bent, undone or disconnnected. Since this is harder (near impossible in fact) to have this happen by just working the camera, hopefully your problem is not this. Your SRT would be still repairable, but at greater cost.
Call around to find a shop in your area that works and knows what they're doing on OLDER MANUAL Minoltas, then check the value of your SRT in your area and have that shop fix your camera at a cost within its value. Once fixed your SRT is still well within its service life: on SRT's usually only the meter-to-prism glue clouding, cable derailments, internal foam pieces gelling, and that pull-rod give trouble (and all these are still fixable).
Also a simple trick to try to resequence an SRT shutter yourself. If when your shutter release button comes back up (after you wind the camera when pushing down the release button), it seems lower than normal then try pushing in the rewind release button (in its U-depression on the bottom of the camera) and try winding the top advance lever (don't force anything, if this is going to work it should be all free moving). If the shutter release button pops up, the camera should be resequenced. It may take a couple of tries.
If it is not the mirror, then it may be the reason below.
The X-700's have a fairly common issue as they age. There is a capacitor inside, which simply gives out and must be replaced in order for the camera to function. If I remember correctly, it is directly related to the shutter release function.
The replacement capacitor is cheap and the repair can be performed by any reputable camera shop that knows Minoltas. There are even instructions on the web on how to do it yourself. My 700 gave up the ghost too, but I just haven't had the confidence to attempt the repair. I came into another functioning 700, so the repair isn't vital right now.
Please let me know what you want to do and what you find if you check your mirror. I would be glad to further assist you.
Thank you for using Fixya and Good Luck
Posted on Apr 22, 2008
informatica
Greg Cann
  • 1114 Answers
SOURCE: Instructions for a Minolta Freedom Zoom 70 C Camera
Hi - You can download the manual by clicking the link underlined in blue below:
Freedom Zoom 70 C
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 02, 2008
Parshiv Luthra
  • 395 Answers
SOURCE: CAN NOT GET FILM OUT
have you tried manually rewind ... there must be a button provided at the bottom ..... if not then get it manually removed by a photo shop ...as you wont b having a darkroom and you might ruin the pictures.......
Posted on Oct 26, 2008
Where and how do you find the battery. minolta riva70 af
Your camera uses a single 3v lithium CR123 battery. Most larger electronics shops sell them at a ridiculous price in twin packs, or you can get single examples such as the Panasonic version for under £2 including shipping on ebay..
The link is for example and convenience only, I bought the same item last week from that supplier. You may prefer to use alternative suppliers and may have to if you live outside the UK, but the point is that they are easily available and don't have to be expensive.
Jun 28, 2011 | Konica Minolta Riva Zoom 70 35mm Point and...
Where do i purchase spools for this camera?
From almost any camera shop, petrol station, drugstore or supermarket.
35mm photographic film remains widely available.
Aug 02, 2010 | Konica Minolta Riva Zoom 70 35mm Point and...
I need the brand new price for a minolta riva zoom 70 af please
These have not been sold new for a while (in the UK).
Do you mean the price of an equivalent camera, or the price (some years ago) when you could buy it new, and in which part of the world.
You can get a lot of them "as new" - from £5 - £20 (inc shipping) on eBay .. for example ....
http://shop.ebay.co.uk/?_from=R40&_trksid=m38&_nkw=minolta+riva+zoom+70
Local charity shops int the UK would have a price tag of £1 - £5 on it nowadays ,and not expect it to sell. Film cameras have died a death here, and this minolta was never a top rated model.
Feb 03, 2010 | Photography
When I push the button to take a photo, the camera
Sounds like a broken gear or linking arm. It will cost as much to fix as to replace. You now have a very nice Minolta paperweight, lol.
Those neat little film cameras are now a thing of the Ebay, LOL. Since many are dumping them for digital, they're quite available at good prices now.
lightspiritphotography.com
Nov 14, 2009 | Minolta Freedom Zoom Explorer EX 35mm...
I have a Konica 7065 and a dont' have the ECM password how can i find it.... Ever Vega
you can accessf the ecm but you have to know the old password to get all the information. if you don;t know you will lose all the info. press p and enter 9272 and it is under 25 mode. the password 12345678.
Jun 28, 2009 | Konica Minolta Riva Zoom 70 35mm Point and...
Minolta Freedom Zoom 90 Camera will not flash
Common problem.
Flash transformer needs replacement.
Mar 30, 2009 | Minolta Freedom Zoom 90 Date 35mm Point...
Won't take picture though I replaced battery.
Even though it was cushioned somewhat the camera took enough damage to jam something. The flashing symbols are a generic error code it could mean the shutter, zoom, film transport, flash, or some combination of these system are not working (sorry but without tearing the camera apart I can't narrow the problem any further)
Nov 05, 2008 | Minolta Freedom Action Zoom 90 35mm Point...
Minolta compact camera
Here's a link to the manuals download page: http://ca.konicaminolta.com/support/manuals/index.html without the model number of your camera I cannot give you a direct link.
Oct 07, 2008 | Minolta Riva Zoom 115 35mm Point and Shoot...
Minolta 70W riva zoom camera
Hey murdyh,
I have included a link below to a PDF download of your camera manual. I hope this helps!
http://ca.konicaminolta.com/support/manuals/film-cameras/compact-cameras/index.html
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Photography
I need a manual
This may not be right -- check closely.
Manual for a Riva or Freedom zoom 130 Check to see if correct (appears on Amazon as manual for 130C)
http://ca.konicaminolta.com/support/manuals/film-cameras/compact-cameras/riva_zoom_130/9222_2476_11(E)-C.pdf
Dec 18, 2007 | Minolta 35-200mm f/4.5 XI for Maxxum
Minolta Riva Zoom 70W Film Camera Logo
81 people viewed this question
Top Minolta Cameras Experts
 Larry
Larry
ray gallant
ray gallant
Malcolm Fowler
Malcolm Fowler
Level 1 Expert
Are you a Minolta Camera Expert? Answer questions, earn points and help others
