2000 Hyundai Sonata Logo
r
richard Posted on Dec 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No spark ferom coil
Why no spark from coil
montehammons
Level 3:
  • Hyundai Master 5,531 Answers
  • Posted on Dec 20, 2013
montehammons
Hyundai Master
Level 3:
Answers
5531
Questions
Helped
1645432
Points
17401
Electrical testing is required. Coil positive wire should have battery voltage with key on. Then, the computer signals the ignition control module to cut primary circuit voltage, after it gets information from the crank position sensor-and other sensors, but primarily the crank sensor. When coil primary voltage is cut, it induces high voltage in the coil's secondary windings. High voltage then travels through the plug wires to the spark plug.
So, no spark could be a bad coil, a bad ignition control module, bad crank or cam position sensor, or even a bad ECU (engine computer). Or it could be a wiring problem. Check for voltage to the coil with key on, as a start.
A
Anonymous
Probable Causes: Fuel Pump (P0230 to P0233) PCM (P0600 to P0606) Crank Sensor (P0355 to P0399) Fuel Pressure (P0190 to P0194) Chances are the Check Engine Light is not on, but you may find any of the following codes: P0230 to P0233 Fuel Pump codes P0600 to P0606 PCM related codes P0335 to P0339 Crank Sensor codes P0190 to P0194 Fuel Pressure Sensor codes No spark due to a bad crank position sensor, a faulty ignition module or PCM, a problem in the ignition circuit (ignition switch, antitheft system, wiring, etc.), a faulty park/neutral safety switch, a bad ignition coil (only on engines with a single coil ignition), or wet plugs or plug wires (did it rain last night, did you just wash the engine?) A less common cause is a worn starter that draws so many amps while cranking the engine that there's not enough juice left to adequately power the ignition system and fuel injectors. Contributing factors might be a weak battery and/or loose or corroded battery cables. No fuel because of a dead fuel pump, bad fuel pump relay, blown fuel pump fuse, plugged fuel filter or line, or failed PCM injector driver circuit or injector power supply relay. Or, the fuel tank might be empty (don't believe what the gauge is telling you), or the fuel tank might contain contaminated fuel (water or too much alcohol) or the wrong type of fuel (whoops, somebody put in diesel instead of gasoline). No compression because the timing belt or chain is broken, the timing belt or chain is loose and jumped out of time, or the overhead camshaft has snapped.
  • Pierre
    Pierre May 05, 2016
    Thank you so far...fact is that the car had no problem starting before the engine wash although the crank sensor was on the blink, new one was fitted as well as cam sensor and ECU was checked and seems to be ok..i suspect that the person with the hose dislodged a connection or something and the ceu picks up no problems at all...ceu cleared..
Can I please see a diagram of spark plug leads attached to the coil pack
Here is a diagram showing the spark plug leads attached to a coil pack:
Ignition coil
Spark plug lead
Spark plug
In this diagram, the ignition coil is at the center and is connected to the spark plug leads, which are in turn connected to the spark plugs. The spark plugs are located at the end of each spark plug lead and are responsible for igniting the fuel in the engine's cylinders.
In a typical engine, there will be one ignition coil for each cylinder, and the spark plugs will be connected to the ignition coils through the spark plug leads. The ignition coil generates a high voltage electrical current, which is transmitted through the spark plug leads to the spark plugs. The spark plugs then use this electrical current to create a spark, which ignites the fuel in the engine's cylinders and powers the vehicle.
1helpful
Cant find plugs on a 3.7 6 cylinder 2 wheel drive dakota please help
3.7L Engines
Each individual spark plug is located under each ignition coil. Each individual ignition coil must be removed to gain access to each spark plug. Refer to Ignition Coil Removal/Installation. Prior to removing spark plug, spray compressed air around base of ignition coil at cylinder head. This will help prevent foreign material from entering combustion chamber.
  1. Remove spark plug from cylinder head using a quality socket with a rubber or foam insert.
  2. Inspect spark plug condition.
To install:
  1. Start the spark plug into the cylinder head by hand to avoid cross threading.
  2. Before installing coil(s), check condition of coil o-ring and replace as necessary. To aid in coil installation, apply silicone to coil o-ring.
  3. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
1helpful
I got code PO 305 on a 2002 Mercury Grand Marquis, what is the spark plug wire part called, is it #5 coil, and should I replace the coil and spark plug and what should the spark plug be gapped at? Thank...
This will have a direct coil over ignition with a coil over each spark plug. The coil is the electrical part over the spark plug. The coil also has a rubber part that is called the boot or spark plug boot. The boots can be purchased separately but the coils will come with new boots.
is it #5 coil,
Have you checked to see if there is any spark coming out of the number 5 coil?
When was the last time the spark plugs where changed? It may be due for all the spark plugs to be changed. The spark plug gap is usually listed on the emissions sticker under the hood. It should be .050 - .056 or very close to that.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
4helpful
2answers
Where are the spark plugs on a 2005 galant 2.4
REMOVE TOP ENGINE COVER,REMOVE CYLNDER HEAD CENTER COVER,YOUR WILL SEE IGNITION COILS SETS ON TOP OF SPARK PLUGS.ALL 4 SPARK PLUGS EACH, WILL HAVE A IGNITION COIL ON TOP OF THEM.REMOVE THE COIL SCREW THEN UNPLUG THE COIL ELECTRICAL CONNECTOR.REMOVE COIL, THEN YOU CAN REMOVE SPARK PLUG.YOU WILL NEED A LONG EXTENSION AND A LONG SPARK PLUG SOCKET TO REMOVE SPARK PLUG.
2answers
How do you replace the spark plugs on a 1998 2.7 Intrepid?
REMOVAL
Always remove the ignition coil assembly by grasping at the spark plug boot, turning the assembly 1/2 turn and pulling straight back in a steady motion.
  • Prior to removing the spark plug, spray compressed air around the coil area and spark plug.
  • Remove electrical connector from ignition coil.
On 3.5L engines, it is necessary to loosen the screws by alternating back and forth. Do not lose the spacers under the coil when loosening the screws.
  • Remove 2 fasteners from ignition coil.
  • Remove ignition coil assembly.
  • Remove the spark plug using a quality socket with a rubber or foam insert.
  • Inspect the spark plug condition.
INSTALLATION
  • To avoid cross threading, start the spark plug into the cylinder head by hand.
  • 3.5L engines tighten spark plugs to 28 N·m (20 ft. lbs.) torque, 2.7L engine tighten spark plugs to 17.6 N·m (13 ft. lbs.).
  • Install ignition coil assembly onto spark plug.
  • Install coil screws and tighten: 2.7L engine to 6.2 N·m (55 in. lbs.), 3.5L engines to 6.7 N·m (60 in. lbs.).
  • Connect the electrical connector.
How to replace 1997 buick inition coil
I just did one the other day. There are three coils. You can determine which one is bad by using the number one spark plug wire and an old spark plug. Put the spark plug in the wire ( while it is still in the coil) and ground the plug against the engine block. Make sure it is grounded solidly to metal or you could get a nasty shock. Have someone start the engine. Look at the spark. It should be fat and blue. Turn the engine off as soon as you have seen the quality of the spark. Pull one of the wires from each coil in sequence and move the number one wire to that coil. Proceed as above. The weak coil(s) will have intermittent spark, yellow spark or maybe none at all. Once you know which coil(s) are bad remove the two small screws at the ends of the coil. They hold the coil down. Pick the coil straight up, pulling the contacts out of the ignition module. Set the new coil in place and screw it down. Both towers spark every time the coil fires so reinstall the wires in either spot on a given coil. Good Luck
2helpful
2answers
Where are the spark plugs in the 2006 ford expedition
The spark plugs are located below the 'coil pack' in a hollow tube in the head. You must remove the spark coil retaining screw to access the removal of the soark coil. The reoval with expose the spark plug at the bottom of the hollow tube in the head. The total spark coil is about 6-7" long and when it comes out that is when you will see the spark plug at the bottom of that tube. It sounds difficult to find but once you know it is easy. There is no coil wire(typical spark plug wire) attached to the spark coil. It is fed by a special connector on the side of the spark coil. Look on the side that has the least number of hoses and equipment in the way. Find the top of the spark coil (about 1-3/4-2" in dia) with a wire connected on the side. There is a single small metric bolt holding the spark coil in place. It will not come out until that screw is removed. I hope that this helps.
8helpful
3answers
No spark to the coil
No spark to the coil or is it no spark from the coil? First verify that you have 12 volts to the coil when you turn ignition switch on if not you will never have spark from the coil going to the plugs. If you do have 12 volts to the coil and still no spark you have a bad coil. To see if the coil is firing, unplug a spark plug wire from it's plug and hold it to a chasis ground while attempting to start the vehicle. There should be a strong spark and popping sound. Remember to wear leather glove or thick work glove if holding the wire by hand to avoid shock. If there is a strong spark then coil is good.
1helpful
How do i plug in the spark plug coils? what order?
If it's the four cyl., the first coil pack bolts over the #2 spark plug. The #2 coil pack wire plugs into #3 spark plug. The number two coil pack bolts directly over the number four spark plug, and the #2 coil pack wire plugs into the #4 plug. The firing order is 1-4-2-3.
3helpful
2answers
1990 Subaru Legacy shorted out the ignition coil. I replaced it and in less than 1 mile,it shorted out the new one.
Subaru engines (including Legacy and engines of many other automobiles, GM, etc.) have returned to so-called wasted spark ignition systems since advent of the electronic distributor-less ignition (having been used historically in early engines with magneto ignitions). With this approach, the ignition systems are less expensive and usually quite reliable. At the same time, however, a shorted spark plug (cracked or carbon clogged, etc.) (or bad ignition spark plug wire) grounds both the ignition spark and the false spark being used. This means that it also grounds the corresponding respective ignition spark of the other 180 degree out of phase cylinder (that uses the same the same coil because the spark current is connected to the spark plugs of two cylinders). Since such a defect allows more current to flow in the spark coil to two plugs when the resistance of the spark plug gap disappears due to a cracked plug, etc, it seems likely to hasten coil burn out if the spark plug/plug wire defect is not corrected before installing the new spark coil.
To explain further, wasted spark means that when a cylinder is ready to fire, it gets a spark to its spark plug while part of the spark (from the same coil and current) as a sort of copy is also sent to another cyclinder at the same time but when the piston in that cylinder is exhausting its ignited gases 180 degrees out of phase from when its spark is needed. When the second cylinder is ready to fire and receives its "spark, the first cyclinder the also receivesa "wasted" spark "copy" of the one needed by the second cylinder. Economy is achieved in manufacture because otherwise electronics would have to turn on and off four different spark coils to distribute four different sparks as needed to the four cylinders. With wasted sparks (which are cheap), because the spark current of one coil is connected (internally in the ignition coil unit) to two cylinders that are in the same position but 180 degrees out of phase in firing, the system can turn on and off two spark coils twice as fast with half the electronics and fire two cylinders that are 180 degrees out of phase. A four cylinder engine thus uses only two coils, a six cylinder engine, three coils, etc., in a wasted spark system.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
