Capital Cooking Titanium X CCE26XRBI (NG) Grill Logo
P
Pete Sidor Posted on Dec 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I convert from liquid propane to natural gas
I have been using lp but want to convert. I do not have the manual and do not know the process or whether I need parts from the manufacturer
Bill Chestnut
Level 2:
Scholar:
  • Expert 155 Answers
  • Posted on Dec 19, 2013
Bill Chestnut
Expert
Level 2:
Scholar:
Answers
155
Questions
0
Helped
40320
Points
404
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 • Grilling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
I cannot find a supplier who can provide an LP to nat gas conversion kit for my 4 burner grill made under the name: Ducane, model # 30400040. Can you assist? Marlin
Perhaps, the reason you can't find the fuel conversion parts is that they are not convertible from one fuel type to another. Ducane/Weber makes both an LP model and a Natural Gas model of your grill, but no conversion kits. Because, as the Owners Manual states "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty."
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3400_4400_NG_OwnersManual_27010342_061008.pdf
Certainly, you could attempt it, Marlin . But it's not the wise thing to do.
I know this wasn't the answer you may have wanted, but I hope it helps you.
1helpful
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
1helpful
2answers
Can i switch a model RN30 from natural gas to propane?
Only the portable heaters that are manufactured to be used on dual fuel (nat gas/propane) can switch from one to another. If they are made for 1 type of gas only, they are not field serviceable and cannot be converted. Douglas
3helpful
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
1helpful
3answers
How do I convert a dacor epicure range ERD48 from liquid propane to natural gas
Just change the orifices. Also adjust the pressure control regulator by reversing the built in plastic spacer, the regulator supplied is a dual fuel type. Any work should only be carried out by a person who is qualified to do so for safety reasons. Dacor are very unhelpful when I posed the same question directly to one of their technical advisors. The poor level of this persons 'technical' knowledge both surprised and concerned me.
1helpful
4answers
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 • Dryers
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Top Capital Cooking Grilling Experts
Paul Carew
john h
Are you a Capital Cooking Grilling Expert? Answer questions, earn points and help others
