Contributor
- Posted on Jan 24, 2014
Re: How to nulock sony xperia s lt26i
Solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
- Make sure the battery is charge properly
- Turn on SONY XPERIA S smartphone
- Don't forget to backup all important data
- Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
- Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
- The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
- Flashtool in the applications from Sony can be download from Sony website.
- Flashtool software need to installed in you computer and ready with USB data cable
- Make sure SONY XPERIA S battery is charge properly or full charge
- Power off SONY XPERIA S
- Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
- Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
- Make sure the battery fully charge
- Do not forget to backup all important data
- Turn off the SONY XPERIA S
- Press and Hold together: Power Button + Volume Up Button for several seconds
- Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
