Maycom AR-108 Air Band Scanner Logo
B
BRUNO CHAMTYOO Posted on Dec 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RECEIVED RF ON AIRCRAFT BAND BUT NO SOUND - Maycom AR-108 Air Band Scanner
Dennis Tokarzewski
Level 1:
  • Contributor 21 Answers
  • Posted on Jan 15, 2014
Dennis Tokarzewski
Contributor
Level 1:
Answers
21
Questions
0
Helped
9382
Points
44
Check for mode or modulation type setting. Aircraft use AM modulation, most other radio bands will use FM.
danoyachtcap
Level 3:
Top Expert:
  • Master 2,907 Answers
  • Posted on Feb 24, 2015
danoyachtcap
Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275918
Points
52081
Aircraft sound is "AM" so don't set your scanner for FM
Hope this helps
My fire stick will not detect my home wireless network. Why?
They are probably not on the same RF band. Check the router bands, it sounds like an older router without all the bands.
1helpful
Can the GRECOM PSR255. be used to scan for aircraft /airband frequencies
Your radio is not capable of recieving air band frequencies. It will only receive 4 bands consisting of: 26 - 54 MHz; 68 - 88 MHz; 137 - 174 MHz and 380 - 512 Mhz.
The VHF airband uses the frequencies between 108 (just above commercial FM radio) and 137 MHZ (just below 2 meter Ham radio). Amplitude Modulation ("AM") is the mode that transmissions are made. The lowest 10 MHz of the band, from 108-117.95 MHz, is split into 200 narrow-band channels of 50 kHz. These are reserved for navigational aids such as VOR beacons, and precision approach systems such as ILS localizers
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
No rf signal between mic and reciever
Make certain the mic and receiver are in the same exact frequency band. There are stickers on both products that indicate the frequency band.
1helpful
I have a Shure PSM 900 and for some reason I suffer from extreme dropouts. I have checked everything I could, batteries, limit switch settings (tried all of them), adjustments on the receiver/bodypack. ...
This system operates in the 600 MHz band. Things to consider: Never use rechargeable batteries in things designed for alkaline. Transmitter should be within 100 feet for reliable link. Interference from other sources will OVERIDE the low power signals for this unit. Such sources can for instance be the fourth harmonic of polce and taxicab radios... fifth harmonic of aircraft radios... other RF sources including computers. All of these devices are SECONDARY users that MUST tolerate interference from licensed primary users of the band. The devices are FM radio links and with FM a transmitter anywhere near the same frequency will "CAPTURE" the discriminator of the unit and you MAY not even hear the audio of the interfering transmitter/source because it may use a different modulation means, if it is even modulated. Just changing to a different channel is NOT likely to fix the problem long term either. Shure makes high quality devices and I doubt the device is defective... only interfered with or being used at too long a range. Use an unused wire in the snake if you use one to get the transmitter within 20 feet of you and it might fix the problem. This unit is NOT a diversity device as in ear monitors are really not diversity (with two antennas and receivers) like ones used to send the other direction often are.
2answers
Why can't i listen to aircraft pilots & tower on my Uniden bearcat BC60XLT-1? Our airband frequency here is 108-137 mhz.
Your scanner does not receive frequencies between 54 and 137 MHz, and there's nothing you can do to enable reception in that block. Your only option is to purchase a scanner with air band coverage. Here are the reception ranges of the BC-60XLT-1:
29.0-29.7 MHz 10 Meter Amateur Band
29.7-50 MHz VHF Low Band
50-54 MHz 6 Meter Amateur Band
137-144 MHz Military Land Mobile
144-148 MHz 2 Meter Amateur Band
148-174 MHz VHF High Band
Above bands in 5 kHz steps
406-420 MHz Federal Government
420-450 MHz 70 cm Amateur Band
450-470 MHz UHF Standard Band
470-512 MHz UHF "T" Band
Above bands in 12.5 kHz steps
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B.
Listening in since the 60's
I have just bought this scanner UBC244CLT and finde that the instruction book is useless, I have been unable to get anywhere with it except to put the time on, the instructions are clear enough for that -...
You are correct regarding the frequencies used by aircraft, but unfortunately your scanner does not cover this range. The UBC244CLT covers 66-87.265, 137-173-995, and 406-512MHz. To receive the aircraft band (108-137MHz) on an economically-priced scanner you will need to purchase the BC370CRS or UBC370CRS.
Bill B.
DO THE DCT700 CABLE BOXES HAVE AN TV TUNER BUILD INSIDE THEM?
RTFM!
  • MPEG-2 digital video processor
  • ATSC standard Dolby® Digital (AC-3) Audio Processor
  • ITU standard 64/256 QAM/FEC enhanced adaptive equalizer
  • On-board real-time RF return (256 Kbps)
  • Bitmapped graphics display (4-/8-bit)
  • 90-860 MHz Tuner
  • DES-based encryption DCII access control
  • Digital diagnostics
  • Frequency agile 2.048 Mbps out-of-band data receiver
  • Macrovision copy protection
  • IR support for remote control
  • RF remodulator output (ch. 3, 4)
  • Baseband video and audio outputs
1helpful
Will the BC248clt receive aviation transmitions VHF and UHF?
Sorry, but the 248 does not cover either aircraft band. To pick up these bands (108-137MHz civil and 225-380MHz military) you'll need to move up to a scanner that provides coverage of these frequencies. For reasonable cost and ease of operation I recommend the BC370CRS.
Bill B
Pro-2052 scanner squeels in the aircraft bands only??
the aircraft band is am while the rest of the bands are fm so i would guess its in the am oscillator or detector circuits or the power supply feeding them. this would be a fix for a technician.
Top Maycom Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Maycom Radio Communication Expert? Answer questions, earn points and help others
