Everything pluged in correctly?
If so the Are you hitting the correct button?
Also what kind of multi-switch do you have? and Is that plugged in correctly
i have unplugged the box and plugged in only one game and i still have the square....any idea where the closed caption may be found ...I have a "set-up" didn"t see it there, I have "customized settings" didn"t see it there and "advanced settings" didn"t see it there....I also have an RCA universal remote....no original....it helps somewhat for the menu...but no "CC" I tried a Comcast remote that didn't help either
SOURCE: Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
SOURCE: mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
SOURCE: Mitsubishi WS-65611 Repair kit from TV-Repairkits.com no fix.....
I have a few ideas but they all will require some more information from you. I know these sets very well-if you fixed the convergence problem my hat is off to you--it can be a do it yourself job but not the most easy set to do it on.
Let me assume you adjusted the convergence in the customer mode--it does on any of the HD models have to be adjusted in the regular and then the HD modes.
The only other thing here that may be the problem is FOCUS. A simple way to determine this is to remove the back cover--turn the set on and call up the advanced convergence grid---then cover the lens for each tube one at a time--with red and blue lens covered are the lines in sharp focus or look blurry?
Repeat this with only red or blue not covered and see what you think--if one of the tubes is out of focus you will see it there--
There is also a TECH menu for adjusting the convergence-like the customer menu but it saves the adjustments into the set's memory--you will need to hit menu and a four digit code based on the actual model number of the set.
Check to see if focus is or is not your problem-easy to tell--green, red, blue lines will either be sharp or out of focus--if out ask and I will tell you the simple way to adjust that.
If this information has helped you rate this solution as I do this here for free.
SD TECH
