Paper feeds into the printer fine but will not turn enough to go through the output rollers at the top of the printer - it just jams and crumples. Just received this used printer from Amazon and it came like this. Was it maybe damaged in shipping and something that could be fixed with just a simple adjustment. I have looked at the rollers (are visible when you drop the back top door) but cannot see anything wrong.
Ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
please check follow:
1) unrunning roller drive gears or delt (rubbon) for any damage
2) check the driver motor running or not
3) if motor never run means motor or drive board wrong
please tell me all above situation, or any question if you can not check
is there any helped you? please take a rating le me know how much helped you, thanks!
please take a rating let me know how much helped you, thanks!
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
It is jamming at the top of the printer (where the paper would come out - it is not feeding through the last roller at the top
You were correct - the top roller is not turning at all and that is why the paper is jamming - can I fix this and how can I fix this?
you need make sure all roller running, might be a roller not runing where is the paper stoping, let me know please
