HP Support Communityhttps://h30434.www3.hp.com > td-p
Jan 5, 2022 - 59 error could be a bad motor or Developer motor rotation error. Remove all toner, power cycle the printer, and re-install one at a time, closing the access ...
59 error indicates a main motor failure. This if often caused by a jammed cartridge, so trying a new toner cartridge would be your first step to trouble shoot this.
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Don't know of a 59.CK error. However a 59.C is a "developing disengaging motor" error. If you are a tech, replace the developing disengaging drive assembly(RG5-6719-000CN).
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action 1.Press the green <Tick Symbol>(Select) button to continue. 2.Turn the printer off, and then turn the printer on. 3.If the error message returns, turn the printer off. 4.Perform a cold reset. a.Turn the printer on. b.Watch the control panel. c.When the memory starts counting, press and hold the green <Tick Symbol> (Select) button. d.Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE. f.Press (Down Arrow) button once. The control panel will display COLD RESET. g.Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence. 5.If this message persists, contact an HP-authorized service or support provider.
