Sony Walkman NWZ-A828 Digital Media Player Logo
Posted on May 15, 2009
Sony Walkman connection problems
I've had my walkman now for about a 6-7 months, i've been away for a while where i have been my walkman, i've updated my antivirus on my laptop since i got back.I've gone to plug my walkman in to the USB port and it's only coming up on the screen connecting, and not letting me put tunes on too it????
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
3017
Points
13
I had a similar problem, mine wouldn’t turn on unless I plugged it in the computer and then it still wouldn’t work!
I found this on Sony’s trouble shooter -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
So I bought a USB adapter charger! Plugged it in and now it is working!
HOPE IT WORKS FOR YOU!
2helpful
2answers
Nwz-e344 sony walkman isn't being recognized by my computer
If your PC has windows XP sp2 or later and Windows Media Player 11 try to do these steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this helps.
Thanks.
gylacz
Mp3 player ( sony walkman) says cannot play please connect to compliant software and update license info
when i try to play the music on my mp3 player ( sony walkman ) it says cannot play please connect to compliant software and update license info. i'm not sure how to do this
1helpful
2answers
Hello, i am a sony ericsson walkman W100i spiro user. I just purchase the phone last month but then for the last 2 weeks, i have experience some problem with my phone. Each time i received new messages or...
Take the phone back, if its still under its 1 year warranty. I bought mine last wednesday and had problems with it straight away. Its freezes and switches itself off. I went back to the shop and they told me there was a fault twith the phone and they can just give me a new one.
9helpful
4answers
BOOT ERROR
it might be serious check out with the service centre ........
9helpful
4answers
Sony walkman b135 say boot error after that power
4helpful
2answers
Sony Walkman NWZ-S639F will not connect to PC running XP.
Yes I had the exact same problem with both Norton 2009 and TalkTalk Super Secure Boost. To solve it you need to go to control panel, switch to classic view, scroll down to 'System', in System select the tab 'Hardware', then click on 'Device Manager', then click on WALKMAN NWZ-S639F and go to update driver. This solution has solved this problem for me twice, should solve your problem too, let me know if it does. Thanks
How do i make my mp3 connect with my computer
I had the same problem. I had not had any problems for months and suddenly it wouldn't connect. I got on live chat w/ Sony (3 times) and finally got someone who seemed to know what they were doing. I have a Sony computer and they had to send me a link for a USB "patch". After downloading it, it fixed it.
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
113helpful
3answers
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Sony walkman nwz-a828kb is not recognised by media manager.
hi ive had lots of problems with sony media centre trying it to accept i video! click the link below and look at the second comment,download the software and ajust the setting on the converter.cant belive it worked hope this helps...
http://www.atraclife.com/forums/index.php?showtopic=4584
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
