RIM BlackBerry  Pearl  8100 Logo
A
Anonymous Posted on Dec 18, 2013
How do you turn the alarm off on Time magazine ultronic>
1helpful
2answers
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
How to set alarm on ultronic world time calendar
This is a question for the app developer, it actually has little to do with your phone and more to do with independant software.
Mar 11, 2015 • Cell Phones
Owner manual for Ultronic weather clock
Press the "Down" button to toggle between Celsius and Fahrenheit.
Press the "Up" button to turn the alarm on and off.
For complete instructions on the Ultronic clock thermometer, see:
https://pdfslide.net/documents/ultronic-clock-cl-266instructions.html
Ultronic td552
Press upper right box 'alarm' until alarm time shows, then press 'set' button and it will toggle between 'off' and 'on' for the alarm.
8helpful
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 • Watches
Ultronic Touch Screen Thermo Alarm Clock TD552 Desktop Model
This may be helpful, it's how I set mine.
1) Remove battery cover
2) Remove batteries
3) "Set" the clock and battery cover into the trash can.
There you go. No more problem !
22helpful
Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
276helpful
13answers
Setting an ultronic clock
Press "Mode" once to view the calendar
Press Mode again to view the alarm time
Set Time:
Press and hold Mode for 3 sec. to enter the time setting...Hour blinks..change by using Up or Down buttons. Press Mode again to set Minutes Press Mode to finish
Set Calendar:
Press Mode to see calendar
Press Mode for 3 sec to set year. Year appears, blinks...change with up or down buttons
Press Mode ..month appears...blinks. Change with up & down buttons. Repeat for day. Press Mode to finish
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
