Olympus FE-230 Digital Camera Logo
A
Anonymous Posted on Dec 18, 2013
Conflicting settings when I set the zoom to on I get a conflicting settings error
When i open the camera and want to use the zoom and press the zoom in button amessage saying lens error 0*2119 appears and the camera swithes off
You need "digital zoom" switched on. Go to the menu and then into the "settings" section. One of the settings will be "digital zoom". You will have to enter into that setting and set it to "ON".
tip
10 reasons why PCs crash-You must know tip 5
5 Fatal OE exceptions and VXD errors
Fatal OE exception errors and VXD errors are often caused by video card problems.
These can often be resolved easily by reducing the resolution of the video display. Go to
* Start-Settings-Control Panel-Display-Settings
Here you should slide the screen area bar to the left. Take a look at the colour settings on the left of that window. For most desktops, high colour 16-bit depth is adequate.
If the screen freezes or you experience system lockups it might be due to the video card. Make sure it does not have a hardware conflict. Go to
* Start-Settings-Control Panel-System-Device Manager
Here, select the + beside Display Adapter. A line of text describing your video card should appear. Select it (make it blue) and press properties. Then select Resources and select each line in the window. Look for a message that says No Conflicts.
If you have video card hardware conflict, you will see it here. Be careful at this point and make a note of everything you do in case you make things worse.
The way to resolve a hardware conflict is to uncheck the Use Automatic Settings box and hit the Change Settings button. You are searching for a setting that will display a No Conflicts message.
Another useful way to resolve video problems is to go to
* Start-Settings-Control Panel-System-Performance-Graphics
Here you should move the Hardware Acceleration slider to the left. As ever, the most common cause of problems relating to graphics cards is old or faulty drivers (a driver is a small piece of software used by a computer to communicate with a device).
Look up your video card's manufacturer on the internet and search for the most recent drivers for it.
on Mar 04, 2010 • Computers & Internet
How can i formate tomtom xl 340s
The errors often occur because changes in HOME's settings conflict with the XL340S. Resetting HOME to the default settings, which requires deleting specific folders from your computer, should clear up most error messages. When returning to the default settings doesn't resolve the error, the cause of the conflict is due to the software programming or how you are using the software.
TomTom's support website has information on which folders you need to delete to reset the device, and information on resolving specific error messages when a reset doesn't work.
how about a data sync cable?
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
I recive the next messege when i tried to turn on the fine zoom on my sp 800-uz from olympus:conflicting sittings......i have changed all the possible sitting to turn it on never the less.it did not...
There is a Menu setting on the Settings 1 page: RESET, which does reset a lot of camera parameters. After that, put the camera off and on again and retry.
6helpful
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
4helpful
2answers
GRAPHIC error
Do not reinstall anything and there is nothing wrong with your hardware! Here is my solution tested successfully in Conflict Global Storm with atleast 4 different computers with Nvidia display adapter:
If you have Nvidia card, you may see rainbow colors over multiple objects and you need to switch the following settings off:
VIDEO->ADVANCED SETTINGS->PIXEL PER LIGHTING OFF.
VIDEO->ADVANCED SETTINGS->VOLUMETRIC SHADOWS OFF
VIDEO->ADVANCED SETTINGS->FULL SCREEN POST PROCESSING OFF.
"settings not the same on the router as pc " says the message...
has the router got a wlan port if so then ask virgin to send you a seperate modem as the set-top box has conflicts with routers this is all the help I can give
2answers
Code 12 error
Its normally a conflict error where devices are allocated the same IRQ, it's important that u understand how to go about it, the consequences can cause more conflicts if done wrongly, so i suggest u read from this site b4 u change anything
http://support.microsoft.com/kb/310123
Help with my Zoom camera. ASAP
there are several possibilities here: 1. another program that was installed or used got the settings all mixed up. reinstall the camera's drivers. 2. if camera is connected via a serial cable (COM), check for serial-code conflicts. 3. if you are using a firewire cable, turn both computer and camera on, and then connect them. do not turn off the camera while cable is still attached.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
