Scanned a picture..........tried to print it out........error message came up (as above)
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
SOURCE: I have a brother MFC665CW getting an error code
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
SOURCE: brother mfc 240c error says print unable 51
Hapens a lot
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
SOURCE: unable to print 51
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
