SOURCE: ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
SOURCE: Beeping Ice Machine
the beeping is a fault code i need to know how many beeps it does before it starts over Also you can shut down the pwr this will reset it but if you dont fix the fault it will return
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
SOURCE: Ice Cubes won't drop
Something is holding your Ice Slab at the bottom from your description.
Some causes are
1 Dirty - scaled up evap, or just dirty w muddy covering,
2 the vacuum breaking holes are stopped up If it is making a sla whith the evaporator warm no ice take a flashlight and hold it where its shining to the back of the evap and look for the light on th cube forming slots next to the ones your shining the light into Upper corners of each hole must be open.
3 The slab is freezing uneve most like cause is a stopped up distributor tube at the top thats feeding the water down the evaporator.
4 On some models thay had a closer fitting water curtian (the cover in front of the slab) and the top of the sheet touched this and caused the slab to stay uprite and continue the "slide" forward.If your curtian is of the older style and has metal hooks on it with verticle slots n the curtian look at the slots and see if the slots are worn making the whole curtian slide down ward I have seen this several times.4B On some older models there is also a plactic coated wire diverter on the bottom infront of the evaporator. If the palstic coating is gone or the bottom or is not even, the slab could hang up there. 4C If you have the newer plastic pins make sure thay are seated in the mounting properly.
5 Nickel plating could be comming off (any copper color on the lower 1/3 of the evaporator?).
6 I have seen some of the horizontal plates them selves be loose and not in flush try pushing and pulling on them especially the ones at the bottom. ANy that are loose and comming out is your problem.
This lengthy extrapolation is by no means all of the possibilities but most of the common ones. If this helps you solve your proble please rate me accordingly. If it leads you to the correct and completed repair WOULDNT WE MAKE A TEAM?? And Good luck to you.
How old is this machine? Was it working OK before now? Did you just get it? Tell me all you can.
