SOURCE: sharp al-1641cs not working
fuser temp is too low or high, replace the thermistor ( temp regulator) in the fuser.
SOURCE: al1631 sharp copier
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
SOURCE: Displaying L and 6 (flashing) on Sharp AL-1000 copier
The L-6 indicates there is a problem with the "polygon motor". This is the motor inside the laser unit. The laser is not servicable unless it is opened in a "clean room" (no dust particles). If turning the copier off and on does not resolve the issue then the laser needs to be replaced. You could try taking off the back cover of the copier and unplugging and re-connecting any wires you can see connected to any board. sometimes it may just be a wire has worked its way loose.
SOURCE: Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
SOURCE: My Sharp AL 1000 is displaying alternatively the
Hello
The error that is on your disply is the following.
The fusing temperature does not reach 175 degrees celsius within 30 seconds of turning on the power, or the fusing temperature keeps at 140 degrees celsius.
In sequence press the following buttons [clear]-[density select]-[clear]-[desity select] the display will go blank.
With the copy quantity keys input 14 and press the start/print button, the machine will cycle.
If the error returns then the thermistor and themo fuse will have to be rplaced.
I hope this helps you
Regards
