DeLonghi Magnifica XS Espresso Maker Logo
N
Niel Posted on Dec 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Delonghi magnifica S ECAM22.110 not frothing
Have cleaned everything but the frother now makes a screeching type noise and does not froth any more.
Vitally Alcher
Level 3:
  • Master 1,645 Answers
  • Posted on Dec 29, 2013
Vitally Alcher
Master
Level 3:
Answers
1645
Questions
Helped
466734
Points
3209
Steam inside the milk
5 Related Answers
Anonymous
  • Posted on Oct 08, 2009
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Anonymous
  • Posted on Jan 10, 2010
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Anonymous
  • Posted on Jun 21, 2010
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
Anonymous
  • 2047 Answers
  • Posted on Sep 03, 2010
SOURCE: We understand that your problem
Based on the information provided above the machine is a bit old as 3 years of regular use is quite a while. If the frothing wand is the only part of the machine which leaks water it can be presumed that a replacement of the part is in order.
It will be advicable if you can afford a new machine to get a new one otherwise get an expert to replace the frothing wand and run a general service of the entire machine.
Water leakages around electrical appliances are very dangerous and the consequences are always disastrous. So ensure that either the device is handled by an expert or replace the unit completely.
Hope this solution has been helpful?
Anonymous
  • 18 Answers
  • Posted on Dec 12, 2010
SOURCE: I have a Delonghi Prima
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Hi, we have a delonghi magnifica s machine and the milk frother is not working. It screeches and spits out water nut no steam. Trevor
The 'o' rings that come on the steam wand at purchase are rubbish. They come off easily without you even noticing when you remove the parts for cleaning after each frothing. The replacement o rings from DeLonghi do the same thing. I eventually went to my local coffee machine repair shop and got an o ring from them. It has never come off in the year and a half since. . . . . and I have no problems with my Magnification S. Now I LOVE my coffee machine!!!!!!
Delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
13helpful
2answers
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
