Question about American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga
Water ridge toilet keeps running - American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga
2 Suggested Answers
6ya staff
SOURCE:
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
Water Ridge dual flush toilet. Why is it filling up with water?
It is filling up with water because it is clogged
Oct 27, 2015 | Home
Water in tank continuously slowly flows out. No flapper but a central tower.
What ever functions as a flapper is defective and needs to be replaced.
Nov 10, 2014 | Home
Water Ridge dual flush toilet issue!!
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
Nov 10, 2014 | Home
How do i fix my toilet which flushes just fine, fills with water then stops but every now and then will run for about 15 seconds then stop
Check your flapper and run your finger around where it seats to make sure there no ridges or cracks. Sometimes the flapper is off center and it will do that. Some other times the water valve that fills the toilet can stick. If it's the water valve change it with a Fluid Master all in one (valve & ballcock assembly) You can adjust the water level right on the assembly for how many litres of tank water before installation. They are very easy to install and alot of unnecessary adjustments will be avoided compared to the old ballcock style.
Oct 15, 2014 | Home
Fix a running toilet
Faulty flapper sealing. After a flush, the flapper does not seat correctly or completely allowing water to run into the bowl.
Jun 08, 2014 | Home
I have a Water Ridge toilet and the dual plunger is inoperative. Where do I get a replacement?
Yes they sell toilet plunger. But it is better to read its review before buy anything from online.
Sep 01, 2013 | Plumbing
HI, you can find needed parts on amazon. here Modern Shower Doors at Amazing Prices I hope this was helpful. cheers
Jun 30, 2012 | Home
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Logo
421 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
