Cars & Trucks Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1983 Nissan Datson truck idle problem(2.4 ltr)
At idle the engine stalls so i have to keep my foot on the gas to keep it from stalling, i moved the screw for the Air to Fuel mixture but no luck...
Anonymous
Level 2:
  • Expert 232 Answers
  • Posted on May 15, 2009
Anonymous
Expert
Level 2:
Answers
232
Questions
0
Helped
149531
Points
940
If it's running well just adjust the idle screw,sits right behind the throttle lever on the carb
Foot slipped off gas peddle while accelerating causing car to stall. Now when I try to start it, it barley idles then stalls. Help!
Check your throttle cable from pedal to engine,may have came loose or something has broke.Make sure floor mats isn't catching at pedal,I am a 350 fan.love to have one.Have a 85 Nissan 720 4x4 with Weber.
1989 will not idle, have to keep foot on the gas pedal
It,s either not getting enough gas or not enough air. Check has and air filters.
1helpful
Starts dies
an alternator won't stall your car, the battery provides power to keep the spark going. It sounds like you could have some bad fuel, if you're able to run the throttle manually with your foot and keep it going that would indicate idle control. but if it stalls still when you are giving it gas. I would guess a fuel supply issue, either water in your gas, or fuel pump. Good Luck.
2answers
08 ss trailblazer stalls on take off
It can be low fuel pressure issue or clogged fuel pump.Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem :------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
4helpful
Car will not start without pressing gas pedal to keep idle speed up. If I keep idle at 900 RPM or higher it runs as long as foot is on gas pedal. It then stalls out when I take foot off gas pedal. No...
Have the idle bypass valve checked, also called idle air control valve.
If that valve is stuck in the closed position, it's not allowing the fuel to bypass the throttle plate to keep it idling, resulting in stalling, but will keep engine running if the pedal is pushed down.
My datsun maxima keeps stalling out weather im in
check air filter first, then replace fuel filter if it has not been done recently and adjust idle speed. check fluid levels while you are under there.
13helpful
Car idles low, stalls after start
Common issue at the shop (i'm a ford technician), here is what I do to correct it.
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
