I inserted a new SanDisk Adapter microSD card into my camera and a message popped up saying the the memory card requires formatting. I pressed okay and a loading screen popped up saying it was formatting. Then it brought me back the the screen saying your memory card requires formatting. it will keep doing this over and over. I even tried an old memory card. Any idea how to fix it?
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
SOURCE: when i turn the camera on....it saids memory card
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
SOURCE: Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
SOURCE: Kodak EasyShare DX4530 Digital Camera Digital
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
