SOURCE: error code LP5
Greetings,
Here is the best solution to the problem as I faced one of similar sort.To help resolve the code 5 error please try the following.
1. Reboot
2. Navigate to \Program Files and delete the \Registry Mechanic folder
3. Download Registry Mechanic from http://www.pctools.com/registry-mechanic
4. Install Registry Mechanic that was downloaded in step #3 above.
Regards,
TechSup1
SOURCE: Error while unpacking program, code LP5.
This can be caused by many reasons,Please post computer an installed software details,This is usually caused by an antivirus program or a virus but can be caused by any downloaded or packaged software
Redownload the software will stop the error code it is not properly download
SOURCE: when i tries to download anything system shows the
I think this is an issue with improper download try using a download manager
Possible Reasons:
1. LP5 means the package is corrupted. This can happen mainly because of some bad download or obsolete package.
2. Obsolete Antivirus
3. Improper Download Software
4. Flash drive
5. Spyware
6. interference from other applications running on the computer
7. During installation of security sites
Possible Solutions:
1. Check For the version of Anti virus
2. Goto control panel /Add Remove Programs/
3. In the list of installed programs we can see the antivirus version.
4. If it is obsolete, uninstall it and reinstall it with the latest one
5. Check For any 3rd party tool that may interfere with the unpacking of software
6. If so un install it.
7. Run Restore disks (or built-in System Restore). It will reinstall the software automatically.
8. Instead of flash drive, use any download manager
SOURCE: Error while unpacking program, code LP5. Please
Please search your registry for this exact string. Copy and paste it to your search parameter.
C:\WINDOWS\system32\svdhost.exe
If you have this, it is a Trojan Virus and you need to act quickly to remove it.
It's an oldie, so most good antivirus programs and anti-rootkits should save you.
Other forms of LP5 may be genuine and related to Zip file problems from genuine programs, and are simply corrupted, but somehow I doubt this is the case.
