I need to get it work since the wires are broken
SOURCE: Loose white wire in B&D 7190 Type 2
If you look at the switch you will see a hole with a brass coloured contact inside. These are grip type connector where you push the wire in and it grips it. Try pushing the wire into the hole and see if you can pull it out again gently. If it holds you have fixed it.
SOURCE: I NEED A WIRING DIAGRAM FOR THE SWITCH ON AMODEL
i don't think you will find a diagram for the switch. find a parts schematic and order a new one. they aren't make to be fixed.
