Question about Learning Curve Toys Toys
How do you change the battery in the gift car that comes with the Thomas around the tree set?
I have the Learning Curve Thomas Around the Tree Christmas set. It has a gift car that plays jingle bells. The battery in the gift car needs to be replaced and I cannot figure out how (or even where) the batteries go. Any help/guidance would be greatly appreciated. Thanks!
6ya staff
SOURCE:
Anonymous
SOURCE: HP Pavillion dv9000 - won't power up
I had the exact same problem so I called HP support.The instructions were- remove power cord from lap top if power cord is connected, then remove battery, connect power cord to lap top then turn on lap top by holding power button down for 30 seconds. It booted up, no problem. The proceedure is to remove static electricity.
Posted on Dec 19, 2007
Anonymous
  • 8 Answers
SOURCE: my gemmy brand light show christmas tree not working........
When you press the reset button on the controller box, then you need to press the small recessed button on the back of the remote control. You'll need a pen to get in there, or better yet a paper clip. That will reset the remote.
Posted on Dec 18, 2008
michigan man
edgar walker
  • 3533 Answers
SOURCE: I need to remove the driver side rear door panel. How do I do it
there is screws under the armrest and everything that looks as if it is holding the panel on then it should come free
Posted on Jan 25, 2009
66 chrgr
mike loshbough
  • 1011 Answers
SOURCE: 2001 Chevrolet K1500 5.3 engine has a jingling noise around fan
it could be the tensioner .or it could water pump.you almost have to take off belt and spin by hand the individual pulleys. also wile fan is still on and truck is off take the fan see if it moves back and fourth front to back it should have no play in it .because it is attached to the water pump shaft.
Posted on Feb 19, 2009
Anonymous
  • 62 Answers
SOURCE: vtech discovery tree manual
here u go buddy...u can download the manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/VTECH/DISCOVERY%20TREE-_E
Posted on Sep 03, 2009
Testimonial: "The link didn't work but thanks for replying. I got the manual direct from the Vtech website instead. Thanks again."
How to mount cb antenna in a tree
alright you came to the right place.My wife doesn't want an antenna on the house so I stuck it in a tree. Here goes. First you nedd to get up in the tree as high as you can without falling or breaking any branches.This is how I did mine. My son and I got up the tree and set an antenna l bracket into the tree to set the antenna on. Then we set the antenna on it and secured it with metal strip banding ( you can get it at Lowes or home depot) About 2ft from the bottom of the antenna attach one end of the band to the treeand wrap it around the tree crossing over the bottom of the antenna. Now move up about 4ft and attach another band in the same manner you did on the bottom. Make sure you have enough coax and connect it to the connector on the bottom of the antenna . Connect the radio and you are set to go. that simple
May 29, 2015 | Solarcon Antron 99 CB Base Antenna - A99
After changing my brain box of my SUV,I start experiencing hard start in my car
possibly the learning curve of the new computer. you must drive the vehicle around in certain conditions based on manufacturers specs. drive the vehicle for about a half hour some wide open throttle for a few where allowable and steady highway speed as well. theres a learning curve as called that the computer must go through in order to calibrate the engine.
ECM Learning Curve Dodge Cummins Diesel Forum
ecm learning curve Google Search theres an example.
May 02, 2015 | Cars & Trucks
SAP IN LEAKING FROM MY PINE TREE, IS THIS A SIGN OF BORES, MY APRICOT LOOKS THE SAME.
Sap is the pines natrural defense and protective measure when the tree has a break or cut in the bark or is being attacked by insects. So the sap could be seeping out from a broken branch or if it is a borer, there would be small holes(1/4 inch or less) in the bole(trunk) of the tree and there will also be sawdust coming out of the holes and around the base of the tree from the larvae eating the tree.
Oct 04, 2013 | Garden
I was given a thomas train and track set, but did not come with battery or charger. I need to know which ones to buy.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Apr 07, 2010 | Learning Curve Toys Thomas the Tank Engine...
Artificial Christmas tree comes in 3 parts A B C
You can probably find instructions online, depending on the maker. What kind/brand of tree is it? Do each of the power cords plug into the next one down, or is there a large multi-tap outlet somewhere (either halfway up the tree or at the base)?
Dec 19, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
How do I change the battery on Thomas the engine? Sam
Does it have a coal car?
If so squeeze the sides of the coal car and the top pops off.
If it's the blue one with plastic tracks then you have to squeeze the 2 center wheels. The rest,I believe,have screws that make it easier to locate a possible battery compartment.
Hope this helps.
If not I'll call my son...he owned them all. lol
Sep 18, 2009 | Learning Curve Toys Thomas the Tank Engine...
Toys Logo
62 people viewed this question
Top Learning Curve Toys Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
