Your Philips GoGear Vibe supports these formats:
audio
video
audiobook format 4.
More support info:
Philips GoGear MP3 video player SA1VBE08K ViBE 8GB
SOURCE: File Format not supported
You have to be sure that the files are all mp3 files, or wma (windows media audio). Check the rip settings in Windows Media Player. If you rip CD's in a format other than mp3 or wma you will not be able to sync the files to your player. I would suggest sticking with mp3 - as mp3 files are compatible with any player, including ipods.
SOURCE: System File Error on Phillips GoGear Vibe
you should be able to put it into recovery mode by holding the volume up button while hooking it up to the computer after that you should be able to do a recovery on it using the software provided with the player
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
SOURCE: whenever i try to play
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Testimonial: "thanks"
