Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Logo
l
louise loughlin Posted on Dec 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brother DCP-J140W won't scan. It keeps saying check connection but it is printing okay. Please help!
It won't scan, keeps saying 'check connection' I have uninstalled and reinstalled several times, but to no avail.
iftikharhmd40
Level 2:
Sergeant:
  • Brother Expert 229 Answers
  • Posted on Apr 02, 2015
iftikharhmd40
Brother Expert
Level 2:
Sergeant:
Answers
229
Questions
6
Helped
128237
Points
636
CHECK SCANNER CONNECTION IN INNER PRINTER
Level 3:
  • Brother Master 6,688 Answers
Cindy  Wells
Brother Master
Level 3:
Answers
6688
Questions
0
Helped
3529808
Points
21744
How is the all-in-one connected to your computer? The problem usually means that you do not have bi-directional communication between the printer and the computer.
If it is connected to your wireless network, did you ensure that the firewall allows the communication? (Some firewalls will automatically add the correct ports to the allowed list during the install of the full software.) For other firewall software or the less-complete install of the software drivers, you need to make sure that the port, 54925 , are allowed to access your computer for inbound and outbound network data. If adding that port is insufficient to allow scans to have bi-directional communication with the printer, also add port 137 (inbound and outbound). Since this step depends on your firewall, please add a comment with the firewall software on your computer. This is in the note in the Scanning section of the Brother Software User's manual for the DCP-J140W on page 35. This manual is available here: http://download.brother.com/welcome/doc002923/dcp140w_use_soft.pdf . An example of setting the Firewall rules for the Windows Firewall is shown starting on page 85 of the manual.
If your computer is connected to the printer via a USB cable, try a different (possibly shorter 6' or less) USB cable or a different port. If you have the printer connected to a USB hub, skip the hub and directly connect to the computer. Check if other devices work at the USB ports. Sometimes ports do fail; either they can't maintain the needed voltage or they don't keep the cable and pins properly aligned.
I hope this helps.
(I have seen the communication issues with stand-alone scanners as well. I saved a perfectly good scanner from the trash when the user failed to check if the scanner worked with other ports.)
3 Related Answers
Anonymous
  • 215 Answers
  • Posted on Mar 30, 2009
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Anonymous
  • 2306 Answers
  • Posted on Jul 22, 2009
SOURCE: my Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
JM Alvis
  • 164 Answers
  • Posted on Feb 08, 2010
SOURCE: My brother printer dcp-165C can't print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
How to solve the problem of see troubleshooting and routine maintence chapter in users guide in .it unable 4f in dcp-j140w wifi brother printer
A print unable message in a Brother inkjet usually means the waste ink chamber is full. This can be fixed by removing the waste bottle, cleaning and drying the pads inside, then reassembling the machine and resetting the purge counter. Most of the instructions for this can be found on u-tube. Please note it is a messy job and many folk just replace the machine.
1helpful
My brother DCP-J140W printer ink box full .. please help how to fix it.
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty.
http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
I have a problem of my printer, it shown in the lcd "Init unable 4F" for brother DCP-J140W printer, what it means?
Sorry... Print head damaged. There is an very low possibility to erase the error without buying new print head, but it's unprofitable
Hello, I have a Brother DCP-J140W printer and the
You can still print in black using the 3 colors. See the printer configuration. After a while it will clear up.
Norman Weimar
Norman Weimar
k24674
