Are you troubled as a result of after you try and set up your H.P. printer by following the steps given at 123.hp.com/setup are unable to search out it on your laptop screen? obtaining a confused bit and pondering what to try to next? Don't panic! simply have a glimpse of the noted lines as there you'll see the fixation procedure of such a problematic hurdle.
Try updating your driver and printer software.
If this does not help, roll-back or install the last working version of the printer.
Make sure that your are using the most recent version of your Operating system, printer firmware and software.
123 HP COM Setup Printer Quick Setup and Install Support
SOURCE: hp 1018 drive for macbook
you can try here for them http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=us&h_query=HP+LaserJet+1018+Printer
are these the drivers needed.
riz.
SOURCE: how do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
SOURCE: I have installed Windows 7 now How to connect HP
When you installed Win7, did you upgrade or did you do a Clean install? If you performed an upgrade, you may have the problem with older conflicting drivers and services. Read this to see what I mean. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm
SOURCE: hp laserjet 1018 printer
Vista sucks, or your l337 "skills"? Don't blame Microsoft for dodgy 3rd party products ...
