I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
it means a particular battery is low or out of the camera, which hold the date and time memory of your videos. don't worry it doesn't affect your any recording or playback of videos. I have one and is blinking from past one month. no issues at all.
The icons from the left:
1. Power indocator
2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive.
3. Power Source indicator
4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
The flashing eye indicates that the red eye minimizer feature is enabled. My NV 10 has buttons on the back that line up with features on the screen. Try to find the one that looks like an eye. That option is often times tied to the flash feature. The flash may be able to be turned on with the same button.
Mine had that too. It means the backup battery is low. It's located in a panel behind the LCD screen. You can find details on page 19 of the users manual. If you don't have your manual, you can download it for free from canon's website.
