I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home >
Printer
Wi-Fi Setup
Setting up a Printer Wi-Fi Network
Using the Control Panel
Using the Wi-Fi Setup Wizard
with LCD panel
WPS setup
You can set up a Wi-Fi network for your printer by using
the printer's control panel.
with LCD panel
If your printer has an LCD panel, you can use the Wi-Fi
Setup Wizard to simplify manual setup.
Note:
This setting is not available for all printers or may not be
enabled.
Make sure that the Wi-Fi is enabled on your computer in
advance.
Check the SSID and password for your network as these are
required during Wi-Fi setup. If you do not know the SSID and password, check
with your network administrator.
For step by step information on setting up a Wi-Fi
connection using the Wi-Fi Setup Wizard, click the following link. This feature
is not available for all printers or may not be enabled.
../p_body/panel/wizard/manual_01.htm *****************************************************************************************
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
