Red light won't go out keeps saying close exit cover. Exit cover
is closed. Turn printer on and off, unplug printer but keeps saying the same thing. Before we replaced the panel light we had to replaced the maintenance kit. Got a red light after we put the maintenance kit in once we took it out a couple of times and restarted the machine the red light went out then after it booted up the red light came up saying close the exit door.
Dont' know what else to do to get it printing again?
Any I did monitor my sensors and they all work fine. other solution to this problem?
I have this same problem but my interlock switches are all working and all the tabs on the cover are present. any other ideas?? Thanks
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
