I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: points gap for a McCulloch 7/10
0.019 - 0.020 in according to this:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/61f60e13d19afbf288256b62001a10e6?OpenDocument
HTH
Lou
SOURCE: Looking for an owners manual for McCulloch
McCulloch has traded hands so often lately Operator's Manuals are hard to find. You should be able to get some help here:
Normal business hours EST
All McCulloch Products
1.800.521.8559
Tell them up front it is a chainsaw, They won't be much help but if enough people inquire perhaps they will improve. Please have saw within easy reach before dialing.
Once frustrated there, go here:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Do a search if not already listed post an inquiry, someone always helps.
An IPL can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
The model number is usually on the bottom of your saw with the serial number. Precede the model number with the hyphenated number from your serial number.
HTH
Lou
SOURCE: flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
