SOURCE: Garmin Nuvi --Can't put state in for address
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
SOURCE: No matches found on garmin 350
Click on the wrench symbol, then the map icon and then "map info". Make sure your map is checked. If it's not, then your map is off. When its off you wont find anything.
- Jim
SHARCNET-USA
SOURCE: No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
SOURCE: Try to type in address and it says state not found or no matches
Your maps are either outdated or have become corrupted. Your best bet would be to update the unit. The new updates will correct your problem as well as give you the neat new item that allows the unit to actually tell you what street/road/freeway you are on. For example "Turn right on Division Street in one quarter mile off of Clinton" and it will also use a "ticker" at the top so a person can read the same directions. You should also check the other options as you can change your icon from a car to a boat to a semi to an eagle to a turkey(leg) to a herse to a jogger to even a snow shovel or a kid on an inner tube. You can add a 2GB SD card and increase the memory of your unit even more. Now the street recognition only works on units 260W and up and you can even change the voice to an elf or a ghoul and add in halloween-xmas-st patty's day and other holidays to your unit.
To do all of this you need to go to Garmin.com and locate the legacy updater on the webpage by typing in your unit and serial number on the bottom. Go here and have fun http://www8.garmin.com/support/download.jsp
SOURCE: nuvi 660/state id problem
Your Maps have become damaged, possible the data file is corrupt or missing. Reinstall from CD
