Error code states E2
E2 is a cold water inlet temp sensor. Has your unit experienced any freezing conditions? If it senses below 36 degrees or above 90 degrees it will show this error.
If its normal temp, and you still get this error...check your sensor. Its an 8(kohm) sensor. Make sure its not open. If it reads ok and your temp is not an issue, then you probably have a bad control board
SOURCE: Bosch Tankless water heater. model AQ 250 SX
Error codes F1 and F2 do not show among common error codes.
Call Bosch 1-800-642-3111
Before calling service technician, open following links for Bosch troubleshoot resources:
Error codes are considered start-point for troubleshoot.
Multiple error codes can indicate PC board failure.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/Troubleshoot/tabid/569/Default.aspx
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
SOURCE: bosch tankless water heater error code ea
Copy following links to narrow down cause for EA error code:
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
