Samsung GT-S5300 Galaxy Pocket Logo
A
Anonymous Posted on May 13, 2017
Hi, My SGY GT-5360 having problem as my lock/power button becomes loose and when i even touch (not press) it.. it locks the phone and shows the shutdown options, and even some times restarts (restart
Hi, My SGY GT-5360 having problem as my lock/power button becomes loose and when i even touch (not press) it.. it locks the phone and shows the shutdown options, and even some times restarts (restart happens when we press and hold the power button for 5 seconds). Im having very problem because it keeps on restarting. I have set the screenout time to 10 seconds so that i dont have to press the lock/power button. But some time when it hit the table the button activates and restarts the phone. Please help guyzzzzz
5 Related Answers
Anonymous
  • Posted on May 16, 2009
SOURCE: Trouble Unlocking Samsung Spex - SCH-R210
whats the code for my samsung SCH-r210
Anonymous
  • Posted on Aug 16, 2009
SOURCE: my samsung SCH-R450 turns off and restarts again
my phone turns off everytime i put in my sd memory card
Anonymous
  • 184 Answers
  • Posted on Jun 24, 2010
SOURCE: i cant acess my setting to calibrate my phone.
Ok there might be a battery issue. Or there might need to be a touch calibration reset. To do that go to your settings and select touch calibration and do it again.
ALSO IF YOUR PHONE IS STILL IN WARRENTY AKA WITHIN 1 YEAR OF PURCHASE THEN CALL 1800 801 1101. THEY WILL HELP YOU. YOU WILL NEED YOUR IMEI NUMBER OFF THE BACK OF THE PHONE. IF NOT CALL THE INSURANCE HOTLINE WHICH IS ON THE AT&T WEBSITE.
Anonymous
  • Posted on Feb 25, 2011
SOURCE: my samsung omnia GT B7730 windows media player
my samsung omnia GT B7730 windows media player won't open nor play song. i have restarted my phone a lot of times and its still the same. what to do? help :(
Anonymous
  • 80 Answers
  • Posted on Apr 09, 2011
SOURCE: My Samsung star GT-S5233W's touch
The usual solution for such a problem is to have your phone's digitizer or touch screen replaced. That is the only solution for your phone's touch screen to work again. Have this done by a cell phone specialist, preferably one who's good with samsung phones.
How to repair a deadbooth android cellphone
There might be possibility of hardware faluer,if the device is not booting.
If you are able to switch ON the mobile by pressing Volume UP key + power button +Home button, it will open in Download mode.
Here you can connect your device to computer via USB cable and use the Odin Flash tool for SGY GT-S5360, and flush the ROM.
You can easly get the Odin over internet and stock ROM for SGY.
In case you have any query, revert me back.
2answers
Too many patterns attempts and the phone was locked
Reset your Galaxy Y s 5360
All your phone data (contacts,photos,messages, aplications,games,files) will be lost Please make backup first if you can!
1.Power off your phone
2.Press together volume up +home button+power button
3.Wait till appears samsung logo second time
4.Leave your fingers down tot the buttons
5.Select "wipe data" with volume buttons
6 Press "home" button to activate
7.Select "yes"
8.Press "home" button to activate
9.Wait till format it's over
10 Select rebot
good luck
Enter network lock key for gts 5360
Hi, it's possible to unlock the Enter network lock key screen with the service on Fastgsm website so see if it would be desirable by you.
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
2helpful
2answers
Forgot my google account password
get to recovery/download mode by pressing volume up button , home button & power button, press these 3 buttons together &hold for 5-10 seconds same time then you will be able to see recovery mode there choose the option wipe data/factory reset,remember it will erase your data even though it will solve your problem.
Please rate my answer.
270helpful
13answers
Forgot user name and password to unlock samsung gt s5302
I have forgot our password and user name.so pls solve my problem.immediately.
My phone is samsung GT S 5302.
Getting bored from Nokia C5-03 touch screen Hang problems & display related problems
Hi @Jayeshsinh DO this steps:
>Check your phone, that is it on.
>Hold and press Green handset + Red handset + Camera key.
>Release holded keys, when you see Nokia logo.
>Now tap your lock code. (The default lock code is 12345).
After this operations your phone will reset and maybe restart.
OR
>Press Power button, until your phone turns on.
After that press Menu button and goto Settings -> Phone -> >Phone management -> Factory Settings -> Delete data and restore.
>Confirm your decision -> press Yes.
>Done
How do I hard reset my virison lg vs920 modle phone
Follow the following steps:
  1. Turn the Power Off.
  2. Touch and hold the following keys at the same time for 8-12 seconds: Power/Lock Key + The Volume Down Key.
  3. Press the Power/Lock Key when you see the pop-up "Permanently Erase User Data & Reset Settings?". Press the Power/Lock key to confirm, or touch any Up and Down key to cancel.
  4. When you press the Power/Lock key to confirm, another pop-up stating "Are you sure you want to continue with erase?" will show up. Press the Power/Lock key to confirm or touch any up or down key to cancel.
  5. After pressing the Power/Lock key, your phone will be restored to factory settings.
Please remember that when you perform factory reset, then all your user applications and user data will be deleted.
Please make sure you back up any important data before a factory reset. I recommend Titanium Backup (https://play.google.com/store/apps/details?id=com.keramidas.TitaniumBackup&hl=en). However, your phone should be rooted.
The picture attached should show you the buttons highlighted in green.
However, if your phone is still in working condition, then you can follow the following steps:
  1. From the Home screen, touch the Menu Key.
  2. Touch Settings > Privacy > Factory Data Reset.
  3. Note: Touch the check box to erase all contents from your microSD card when the phone is reset.
  4. Read warning and touch "Reset Phone".
Hope that helped.
Cheers,
Sami Memon
Aug 17, 2012 • Cell Phones
155helpful
10answers
Unlock samsung galaxy y (GT-S5360).to many pattern attemps
1 - Press Volume + , Home, Power
2 - use volume to select wipe data/factory reset
3 - Yes (delete) all user
4 - It will reboot
5 - Done
Good Luck!
Mar 29, 2012 • Cell Phones
1helpful
2answers
How to restart an ipod touch....it has a password lock on it
hi just a tip hope it would work!
1.hold on the power button until you see the "slide to power off" slider
2.let go off the power button and slide the slider
3.wait until it turns off completely. press the power button again to turn it on
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
