Broderbund PrintMaster Platinum Logo
A
Amy Garcia Posted on Dec 15, 2013
I can't find how to make a mirror image
Trying to print an iron-on transfer but can't figure out how to make a mirror image to pring
Mirror image
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image check box.
9. Click OK, and then click Print or OK in the Print dialog box.
Read More.....HP Printer Support
Thanks,
Printing mirror image
Check for the printer settings, if it has mirror image feature. Other wise, or try once below settings:
from the list.
You can avail our technical services by visiting our website; http://www.vtechsquad.com.
1helpful
Trying to print iron on transfer...can't find the mirror image or flip in preferences anywhere...
Open Control Panel
Open Printers and Faxes Folder
Right click on the printer icon and choose Printing Preferences
Under General ( or advanced ) tab you will find Mirror Image
Turn it off and Click OK button
Using a C3100 series HP inkjet printer, I'm trying to print HP Iron-on Transfer Paper but when I select that option, I cannot get the appropriate reverse image need for ironing on the transfer. What's...
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
Where is my mirror image feature?
Looking at the User Guide, it appears that the Mirror Image option may require you to select "Iron-on transfer" as the paper type (see p. 96 in chapter 7):
1.
2. Make sure the HP All-in-One is the selected printer.
from the list.
8. In the Printer Features area, select On from the Mirror Image drop-down list.
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
8helpful
2answers
How do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
1helpful
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
