TV eventually "warms" up and color is restored. Until the last couple of days this never happened. The dark side is always on the left of the screen and changes to color gradually from the outside in until the entire screen is OK.
SOURCE: I have a Sanyo DP42746 and it is about 3 years
2. Upper Y-Buffer
Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3.
Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD
$64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for
parts to USD $277.50. From my research, a shop would probably charge between
USD $500 and $700 to do this repair.
SOURCE: I have a 46 inch sanyo lcd 1080p that is only 2
I'm having the same problem with the same TV. I called around to repair shops and I guess it's fixable. Haven't taken it in yet but I was told it most likely is a bad module. But this seems to be a really common problem with this television
SOURCE: Our television has a dark shadow on the right hand
Bad panel (screen) hopefully you can get one under warr. otherwise, you are stuck with this. contact sanyo directly and make some noise
SOURCE: Our sanyo lcd tv is a couple of years old and
Hello; I am John at J. D. Electronics, Poland Maine. This problem is caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo and less than $400.00 from Encompass Parts Inc.
This is a LCD TV not a plasma TV. It is DP46840 Sanyo 1080p HDTV
I do NOT know how the description changed to Sharp from Sanyo..... but this a Sanyo LCD TV, not a Sharp TV, not a plasma TV. Why does this keep on changing to something that I do not input?
