Bosch AquaStar 2400ES-NG  Logo
Sheri Dave Trautmann Posted on Dec 15, 2013
Bosch GWH2400 ENG has an E2 message - Bosch AquaStar 2400ES-NG
quattro1869
Level 1:
  • Contributor 30 Answers
  • Posted on May 06, 2014
quattro1869
Contributor
Level 1:
Answers
30
Questions
0
Helped
9781
Points
32
E2 is a cold water inlet temp sensor. Has your unit experienced any freezing conditions? If it senses below 36 degrees or above 90 degrees it will show this error.
If its normal temp, and you still get this error...check your sensor. Its an 8(kohm) sensor. Make sure its not open. If it reads ok and your temp is not an issue, then you probably have a bad control board
I have a new worcester bosch boiler with error code E2 222,which is saying in the book flow senser problem , but this bolier is brand new
In that case get it repaired under warranty. Do not attempt to repair it yourself for two reasons:
  1. it could invalidate your warranty
  2. unless you are GasSafe (or equivalent) registered, it's against the law to repair gas appliances, even your own, for obvious reasons, both explosion and carbon monoxide.
Error code tankless gas
Error code e2
Bosch tankless water heater error code
Try a new sensor . I cannot see who told you to wipe the pipe it will do nothing .
Error code e2. inlet water temp sensor. any one have to fix this?
Before calling service technician, open following link for Bosch troubleshooting resources, including error codes, manual, Bosch contact info, and service bulletins.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are starting point for troubleshoot.
e2 is cold water temperature sensor fault.
Bosch error code says: 1) Check connector on wires coming from top of water valve for a secure connection.
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions Any damage due to freezing conditions is not covered under warranty.
Another contributing cause can be temperature thermostat set very high and tankless sensor is going bad, and very cold incoming water, or combination of factors above.
Also read manual for advisories and required maintenance. Some units require water filter be cleaned monthly.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Have to keep resetting E2 is what keeps flashing?
Check wires coming from cold water line valve. Make sure incoming water is above freezing
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
