I have a WELLTECH 40699 FKH51A wireless headphone and replaced the rechargable batteries but it doesn't work. When connected the red en green light on the base station don't light up. On the headphone only the red light burns slightly and all I hear is a static noise. I have used the headphone for many years and it worked fine and wears comfortable, but now it's not working anymore. Who can help me getting it fixed ?
I have a same problem and i did som think crazy i did shorting between the battery contact an the charging contact and contact the basic unit nothing happened but my headphon work not more, have any one idea what happend? how kan i fix this problem?
I the red led only comes on dimly, the new batteries are suspect, or they are not charged. You need to establish if its the headphones or the batteries at fault. To check the headphones remove the batteries and connect up some none rechargeable battery of the same voltage to the headphone battery connections. To check the batteries use a multimeter to measure the voltage at their terminals while they are out of the headphones. If its low compared to the value printed on them, you can either try more new batteries again, or replace the headphones completely.
SOURCE: remote will not work
if the light is staying on this means that a button is stuck down on your remote. It might be defective I would contact the company about warranty.
SOURCE: Remote AH5901643G remote not used
Hello
Just look on its battery contacts first, for any rust or dirt accumulated on it. Clean it with a edge of a razor baled and insert batteries and check. If this dose not help you, you have to open it, and clean the contacts. There may be fungus accumulation. Clean it with medical quality turpentine or rectified spirit. Never use strong solvents like petrol or others, as thay will damage the rubber parts. OK.
SOURCE: already replaced batteries still doesn't work?
Check the battery contacts for any rust or dust accumulated.
SOURCE: Sony remote control GD001 - volume control doesn't work
Your remote control need cleaning.
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. There
are more than 700 posts to different brand TVs now.
Pull up older posts there. Cleaning procedure to remote control is given in detail.
SOURCE: Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
