Onida 29 inches colour flat tv circuit diagram the h coil has been burnt location no L-501 IF I PUT NEW TRANSISTOR TT2142 WHEN I ON IMMEDIATLY TT2142 GETS SHORTNED WHAT IS THE EQUILENT H WIDTH AND HOR FREQ IS A FIXED HCOIL HOW TO SOLVE THE ISSUE
If you wish to get more details, check this link. Hopes it will help you. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or
type in thebrand name and model number to of your set, to its
search box, and press 'Enter' or view it in Mosaic /
Timeslide option.
1. Check the opto coupler in the SMPS circuit. Replace it with
new one. DO NOT SWITCH ON TV WITHOUT OPTO COUPLER.
This is feed back, to the switching transistor to control the oscillator.
2. Horizontal out put transistor going defective.
This is due the failure of diode near the EHT coil primary and
the transistor. The reverse leakage of the high voltage diode can not be
checked by the meter. Hence replace all the black coloured diodes
in the horizontal deflection circuit diodes with identical part no.
Horizontal out put TR will get over heated and will rupture. When you
replace with new transistor switch on TV and switch off immediately.
The heat sink should not get heated or warm up. This is the only way
you can protect the transistor when you replace other components one
by one.
After checking all the small components, finally EHT coil.
