SOURCE: Ice build up
You must replace the defrost heater and thermostat located behind the freezer wall panel.
SOURCE: Ice build up in the bottom of the freezer
Hi, Remove the rear panel inside the freezer and locate the drain ole. Remove all the ice and flush the drain with hot water. Try pushing a soft wire through the drain to make sure it is clear. A baisting seringe to blow water though the drain.
I hope this helps you. please let me kow if I can assist you further.
Vic
SOURCE: My Lg bottom freezer refrigerator, model #
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
SOURCE: ice build up in freezer
It depends how long this has taken to happen. It might be a buildup over years of which a complete system defrost might put it back on the righ path. If its happened over months then it could well be the defrost timer or defrost heater. Either way, a complete system defrost is probably in order (clearing the drainage hole and any standing water in the frrezer) and then you can monitor it regularly to see if the ice buildup happens again.
