Oven reads 100 degrees and will not heat up except for broil. I removed the element and tested the recipictle it only reads 47 volts
SOURCE: the bake on my oven does not heat up ? what's the problem
Hi and welcome to FixYa.com!
First thing to check is the bake element. Examine it for signs of blisters or cracks. If you have a VOM, check it for continuity. It is likely that your problem is just a open bake element. Very common problem.
Hope this helps you and Happy New Year from the FixYa crew!
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
SOURCE: oven heating really slow
yes it sounds as if there is a "HOT-SPOT" on the element which will look like a dis colored spot and will be either bubbled up or have pock marks where its burning thru and can no longer pass sufficient current to heat the element fully
SOURCE: SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
SOURCE: My oven will not warm up. It will just stay at
My dear friend, i suspect the oven thermostat to be responsible for this. It is a switch that opens when the temperature of a oven is set. Therefore it is bad and cannot work according to the temperature it is set to. The thermostat is located at the control panel where a liquid filled temperature sensor bulb which senses and maintains the temperature of the oven by turning it on and off at every cycle.
First You have to test the thermostat before replacing it. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution! Since i do not know the exact maytag oven type, here is the general process for all types of oven.
To replace the thermostat of the oven, please follow the steps below:
Hope this helped you. Thank you for using fixya.
