Press the trip meter select/reset pin until you the oil life
reminder is displayed
Press and hold the select/reset pin down for approximately 10
seconds until the oil life reminder is blinking
Press and hold the select/reset pin down for another 5 seconds or
so until the oil life reminder is reset to 100%
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Lost the operator guide, or never looked in the glove box?
its there.
you can google that. and find it, like 100000 ask ,.
nobody ever looks at the manual or throws it away or not replace it.
dont get stranded, keep it in the car. here it is, no lost.
read page 248 , not clear the solution, ask then,.!
http://justgivemethedamnmanual.com/honda/honda-fit-owners-manual/
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the key off after the the light has finished flashing, then start the vehicle. If the CHANGE OIL SOON indictor comes back on, the engine oil life monitor has not reset. Repeat the procedure again. If the vehicle is equipped with the U20 option code, the vehicle as an oil life low indicator. The oil life low indicator shows an estimate of the oil's remaining useful life. When the oil life index is less than 10 percent, the display will show OIL LIFE LOW. To reset the oil life monitor, press and hold the MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to 99 percent.
