Error code c0500
Mam,
Open the front door lay down on the floor and look up at the section that is slanted (close to hinge side of the front door) Fine the small hole with the machine on, fine a small non metalic stick and in-cert into the small hole touching the small switch which will re-set the machine for C-0500 codes. Do this once if the code comes back replace the fuser, DO NOT RE-SET again messing with FUSER can catch on fire will ruin a perfectly good day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
