Kodak EasyShare CX6200 Digital Camera Logo
R
Rick Posted on Dec 14, 2013
Green pictures All pictures taken have a green tint to them
Bern Meister
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 14 Answers
  • Posted on Dec 17, 2013
Bern Meister
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
14
Questions
Helped
8500
Points
19
Assuming the camera is not faulty the most frequent reason for a green tint is the selection of the wrong white balance in the camera menu. The menu will contain "AWB", "daylight", sometimes represented by a stylised sun logo and indoor. If you use "daylight" for indoor photos the pictures will have a green cast. Select "AWB" for generally acceptable results. If the pictures have a green cast on outdoor pictures you have a problem
2helpful
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
All the pictures have green tint? What is wrong?
Most likely you have changed the "Color Balance" setting. Usually this would be on "auto", and the cameras do a pretty good job of picking the right balance. Sounds like you have fixed it to some value. Go through all of the settings to what it is set at.
4helpful
2answers
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
2helpful
Green Tint
bad optical block call sony they have a recall
2answers
Green Tint
Green tint is caused by a burned or distroyed filter in the optics. It must be removed and sent out to be
rebuilt or replaced.
2answers
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
5helpful
2answers
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Green tint to pictures
This a CCD fault- it should be returned to the Vendor if under warranty or contact Maskers Website
2helpful
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
2answers
Intermittent green tinted pictures (both indoors and outdoors)
The only recommendation is to correct the colour balance in a photo editor in your computer Come back here if you do not know about photo editing. As far as the camera is concerned there is no remedy as far as I can see -its old age time for a new one Repair is not an option.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
