Question about Samsung Yepp YP-P2 Digital Media Player
Samsung yp - p2 not recognized by computer
When connected to the computer by the usb cable it says that it is not recognized. iv downloaded all software that was supplied and more that has been suggested in the threads but it still is not working..... please help
Anonymous
SOURCE:
Anonymous
SOURCE: mp3 player from Samsung YP-U3JQB/XAA not recognized by my pc
Very helpful the Best Solution...thanks.
I've been trying for over a week to solve the problem with this YP-U3 and was about to return it and than I tried this and it worked....
Posted on Apr 03, 2008
Anonymous
  • 3 Answers
SOURCE: yp-t9j
i have the same problem as above. where should i download this?
Posted on Jun 11, 2008
Anonymous
  • 3 Answers
SOURCE: supported video formats on samsung yp-p2
ATM im having alot of problems with videos on my P2, originally when i first bought it, i am pretty sure it played almost every format, MP4 to flv, but not for sum unknown reason it doesnt, and even the software emodio, (which is ****) wont even recognise these videos and when it does it doesnt even transfer into the emodio library. Really ticking me off. P2=great but there is a few teething problems that you dont get with ipods.
Posted on Feb 24, 2009
Anonymous
  • 55 Answers
SOURCE: i have problem
if you are haveing a problem with your computer not recognizing your media divice you should go to the start button on your computer then right click on your (my computer) button then go to properties then go to hardware and then device manager now in your device manager window you should scroll down untill you find the USB controllers and in that tab go to the usb conection that has the question mark then right click on the item and go to properties then search for the key words mass storage device and then troubleshoot the item or try to reinstall this device.
Posted on Jul 23, 2009
Anonymous
  • 106 Answers
SOURCE: My P2 is not recognized by the computer
this problem is due to usb driver not properly installed. do one thing plug that device in another pc and watch whether it is recognised or not. if it recognised then u will have to install usb driver from ur motherboard cd and if not that then u need driver for that device to work properly in ur pc and u get that driver in the device manufacturer cd or website. for this search go to www.google.com.
Posted on Sep 08, 2009
I need free download of driver software for Panasonic PV-DV910 palmcorder for my pc with widows 7
There are none to download. Panasonic suggests the following when the computer fails to recognize the camera:
  • After re-inserting the SD card into this unit, reconnect the supplied USB cable.
  • Select another USB terminal on the PC.
  • Connect the supplied USB cable again after restarting the PC and turning the unit on.
  • Digital Palmcorder Camcorder
    Dec 17, 2015 | Panasonic Video Cameras
    Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
    Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
    Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
    Camera is connected with USB and I don't see software to install
    The problem is that you need to install the software before you connect the camera for the computer to auto recognize it.
    If you dont have a disk that came with the camera to install before connecting the usb cord, go to the internet and search for the manufacturers website and download your software instead.
    Download the software to your computer and follow the prompts for installing it. Then connect your usb cable. if the computer does not auto recognize the camera after the softwares been installed then you have a problem.
    Mar 27, 2011 | Cameras
    I installed the PC Suite for my LG BL40, but it won't connect via USB and my computer doesn't have a bluetooth device. |Ive tried everything suggested and when I connect choosing Music Sync, it connects bu...
    First, syncing is the transfer of data between computer software's that are designed to acquire and share with another entity. The sync function usually is embedded in the computer program. Once the computer recognizes compatible software that has several capabilities including transferring data, a USB connection capacity should be achievable. Usually devices that are designed for data transferability should be capable of acquiring a USB connection either as physical cables or wireless Bluetooth technology. The power to sync is contained in the software program. Once software that has sync capabilities is installed on the computer, any USB cable that is attached to an empty port would display a user message asking for further procedures. For example, USB connections on the computer that has media software's would display device recognizes link requiring data transfer. The solution lies in the software that is relied on for sync capabilities. Acquire Windows Media player, Real One player, or ITunes player as downloadable onto the computer to achieve compatibility.
    Important Notes
    USB ports are available on all computers as versatile connection links to devices that would require communications. The computers original systems are expected to recognize USB cable connection as manufacturers default. Usually, the computer is likely capable of upgrading several software programs that would least communicate with the USB. For example, the program suit installed has compatibility requirements to perform on the computer as an entity. Also, the program suit requires compatibility with USB connection for another device that would be connected to the computer. Attempt to install media transfer programs that are designed with sync features.
    Jan 26, 2011 | Computers & Internet
    I need to download video from DCR-TRV33 to windows. Cannot find software that is compatible. Plugging in a USB cable from the camera to the computer also isn't recognized.
    Since you are using a USB cable to connect the Camcorder to the Computer, it is required to install the USB Driver and the supplied Software to transfer the videos from the Camcorder to the Computer.
    The required USB Driver and the ImageMixer Software have to installed from the supplied Software CD.
    The detailed information to install the USB Driver and the ImagerMixer Software from the supplied CD is mentioned on the page # 153 to 157.
    Click on the link below to view the instructions to transfer the videos from the Camcorder to the Computer using the USB cable.
    http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
    You can also transfer the videos to the Computer using an i.LINK cable.
    The i.LINK cable is better than the USB as the former transfers the videos digitally and the latter in analog form. Hence, the video quality is good for the videos transferred using i.LINK.
    You will not need any supplied Software to do this.
    You need only the i.LINK cable and the video capture Software like Windows Movie Maker(Pre-installed) in Windows Xp Computer.
    Click on the link below to view the instructions to transfer the videos using an i.LINK cable.
    http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
    Jul 20, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
    Need a free download for my sony cyber shot dsc-w55 to download pictures on my computer
    You do not need any Driver or Software to transfer the images from the Camera to the Computer.
    1. Set the USB Connection or Transfer mode setting in the Camera menu to Mass Storage or Normal .
    2. Connect the Camera to the Computer using the supplied USB cable or any USB cable.
    3. The Computer will recognize the Camera (make sure that the recording media containing the pictures (Memory Stick) is inserted in the Camera).
    4. Click the Start button and then click the "My Computer" icon (for XP Operating System and for Vista or Windows 7 it will be "Computer" icon).
    5. In the "My Computer" or "Computer" window, click the icon that represents the Camera.
    6. Click the "DCIM" folder and drag it to the desktop screen of the Computer to transfer the images from the Camera to the Computer.
    However, you may download the supplied Picture Motion Browser software for the Camera from this Link.
    http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4598&mdl=DSCW55
    Good Luck!!!!!!!!!!!!
    Nov 18, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
    USB DEvice not recognized
    Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
    Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
    Download images to view the computer
    With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the selection screen for USB. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. There are instructions available at our web site (http://www.olympusamerica.com/download). For editing and managing image files with a PC, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the USB cable provided.
    Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
    Download images
    Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
    Download images
    With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the USB selection screen. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. To edit and manage images with a computer, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the provided USB cable.
    Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
    Samsung Yepp YP-P2 Digital Media Player Logo
    67 people viewed this question
    Top Samsung Audio Players & Recorders Experts
    ThaMp3Doctor
    ThaMp3Doctor
    Marvin
    Marvin
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
