THERE IS POWER COMING TO THE MACHINE BUT THE MAIN MOTOR IS OFF.
The first thing to try is the fuse. The best way to do this is swap the machine's fuse with that in your kettle's plug - this should also be 13 amps as on your machine.
Also, it is possible that there has been a power cut; even though these are rare they can happen, so do not dismiss this possibility.
The final thing to try is to move the cable and see if the machine will come on. If the machine comes on then you will need to contact the manufacturer for advice about their repair service
SOURCE: Where can i download a manual for my juki ddl-5550-6 for free?
sewingmanuals.com
Have you tried sending information to a Juki dealer? It's unfortunate/fortunate you can find some manuals online and have to pay but...
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
