SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
SOURCE: toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
