SOURCE: error code
805 codes are usually associated with fixing exhaust fans not powering up. Usually due to a blown SMD (Surface Mount Device) fuse on the DC controller PCB.
SOURCE: when i start canon photocopier ir-2016j , its
Your machine appears to think it's waiting for a file (like an update). Somehow it was put into download mode (only a canon tech would know how to). You need to have a canon technician to either reset the machine or if there is a legitimate problem put it into factory default.
It may be a hard drive error from my experience.
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
SOURCE: ir 2016j system error e007
Your fixing film is damaged.
Replace the Fixing Film - it is not easy to do.
Call a technician to install it.
Or buy a new Fixing part : Fuser - Fixing Film Assembly 120V : FM2-3346
Fuser - Fixing Film Assembly 230V : FM2-3353
http://bopcanon.com/images/view.aspx?productId=106
I hope it helps
SOURCE: Error E000024-0001 on Canon iR 2870 Photocopier
WHEN MAKING A FIRST COPY OF ANY DOCUMENT THE FOLLOWING ERROR APPEARS e000024-0001
