The lamp won't ignite, it shots down after trying to ignite, power led goes green and the lamp led flashes red 3 times, a pause on the red, then 3 more times, then a pause on red etc etc.
I used compressed air and i bought a new lamp. Now it works like a charm. Right now, the projector has been on for almost 20 hours and counting.
Before changing lamp use a canister of compressed air to remove dust specially inside the projector when lamp is away.
The lamp ballast module is faulty
SOURCE: LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
SOURCE: Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
